ross-skyenergy avatar image
ross-skyenergy asked
GX LTE 4G - 154 DNS Error (fixed)
Hi
I have lost communication from a Venus to VRM portal for the last 5 days, upon a site inspection I found VRM setting to have the error #154 DNS Failure
The GSM settings seem all okay and the internet shows, "Online"
Firmware 2.6 on the Venus
The system was working fine for about a month.
Venus GX - VGXgsm
David avatar image
David answered ·
Initial feedback from Victron below, which we will check to see if this solves the problem:
- Please first check SIMcard in other device, or try known working SIMcard in GX. 99% of time these problems are from non-working SIMs (run out of data, etc.)
ross-skyenergy answered ·
It turns out Telstra had mistakenly barred this sim card's data usage... problem solved
alan avatar image
alan answered ·
I've had this same thing crop up whilst on site, on wifi from a 4G router.
Tried multiple dongles, reboots, https off etc with the same response.
omondi-odhiambo avatar image
omondi-odhiambo answered ·
Hi @ross-skyenergy and @Alan. Error #154 DNS Failure means that the CCGX has no internet connection. See CCGX manual for more details.
ross-skyenergy avatar image ross-skyenergy commented ·
Hi @Omondi Odhiambo
  1. The CCGX communicated to VRM successfully for at least a month before this issue with no changes
  2. The GSM module is showing the Internet as "Online"
Any other suggestions?
