Jmarc avatar image
Jmarc asked
Is the DVCC current limit a dynamic limit?
Is the DVCC charge current limit dynamic?
Currently running a system with a Quattro whose charge current seems to be limited to 50A which was the DVCC limit. I changed the limit on the CCGX from 50 to 70A. But charge continues at the same rate. The unit is not limited by the AC input current. It is below 50% of the AC in limit.
The BMS has a 600A charge limit
So what is limiting the rate of charge?
Therefore I am wondering if the Limit is a dynamic limit or a set-point sent once at the beginning of the bulk sequence or other trigger. If so which trigger.
MultiPlus Quattro Inverter ChargerBMSDVCC
Elimac avatar image
Elimac answered ·
Did you check the internal settings on the Quattro?
Try see what is the current charge current setting with VEconfig.
