hour avatar image
hour asked
Set Charge Current on MPPT via HEX
The last piece of my puzzle now that I can communicate with the hex protocol from a microcontroller over VE direct is to set the charge current depending on some conditions.
Can't manage to find an example formatted a way that would work for me, here's an example of what I'm sending to disable the charging:
":80002000447\n" and that works great.
Would anyone be able to assist me in figuring out what to send, in the above format, that would do say... 5.5 amps? I learn by example, sorry to bother, but if I can identify which characters in the overall string represent the 5.5 then I can wrap my brain around this and start sending things other than 5.5.
Thanks much!
MPPT ControllersVE.Directcommunication protocol
Danakil avatar image
Danakil answered ·
Hi Hour,
Maybe it's a bit late to answer you but I'll give it a try.
According to Victron documentation, to set the charge current you need to use the 0x2015 register (page 19) instead of 0xEDF0 for a control loop. Check at the warning page 9.
So to set up a 5.5A charge current, here is transmission frame :81520003700E1
Good luck in your project
Best regards,
Nicolas
VE.Direct protocol FAQ
MPPT Product Page
MPPT Error codes
