xdorland avatar image
xdorland asked
Lithium battery (not a Victron)...but with a Cyrix-CT (...not a Cyrix-Li-CT)
A few month ago, I hade to change my GEL batteries by a lithium battery on my camper. The seller told my "you have a Cyrix, so you can have a lithium battery".
I know discover that the Cyrix-CT connect ALWAYS my lithum battery with the engine battery (...which is a lead battery of course)
==> The voltage of the two (very different) battery are always the same
==> When I strat my engine ON...the lithium battery always "helps" the engine battery"
==> Big problems for the future.
==> What solution can you propose to me?...I could replace ce Cyrix-CT by a Cyrix-Li-CT...but it is written on the manual that I need to have a Victron VEBus BMS https://www.victronenergy.com/upload/documents/Manual-Cyrix-Li-ion-120-A-EN.pdf
Thank you in advance
Lithium BatteryCyrix Battery Combiner
The thresholds of the normal ct are to low and you get the behavior you currently have.
So you should replace it with a li-ct and connect 85 to (+) of your battery or BMS if available.
xdorland answered ·
Thank you for your answer.
...si you think that I can just replace the cyrix -CT by a cyrix-Li-CT?
...but what about the Victron l'animal instructions ? I do not have to have a BMS? (It is even written that it compulsary...but in a French website of a seller : https://www.myshop-solaire.com/coupleur-de-batterie-cyrix-li-ct-12-24v-120a-victron-energy-_r_851_i_706.html
