Reyn Moran avatar image
Reyn Moran asked
Help Selecting Products
I have a project that requires an off-grid battery storage and inverter solution. I have a 120vac 10amp load that needs to be brought off grid. I don't care which battery config (12vdc, 24vdc, etc.), but if I can manage it, I would like for this entire project to be purchased from one vendor (ie Victron). They only thing I would like to incorporate that I already have is the Yangtze solar panels listed below.
More details:
Load: 120vac, 10amp
Solar Panels: https://www.yangtze-power.com/solar-panel/monocrystalline-solar-panel/380w-72cells-perc-mono-solar-panel.html
Calculations I'm using for reference: https://www.batterystuff.com/kb/tools/solar-calculator.html
MPPT ControllersPhoenix Inverteroffgridsolar
This community is not the place to ask for system designs.
Take a look at this map and look for a Victron distributor close to you and ask him for advice.
Reyn Moran avatar image Reyn Moran commented ·
I am new to this forum. Apologies. Also, I do not see a link anywhere for the map, but I am assuming you are linking the vendor/partner/distributor locator. Thanks!
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Reyn Moran commented ·
