pganguet avatar image
pganguet asked
Passthru bug CCGX?
Setup: two multiplus 3k in parallel. No assistants. No BMS. No ESS. No DVCC. Powerassist is disabled on both inverters to allow input current setting lower than powerassist minimum.
Problem: If I set the input current limit to 0, inverter goes to passthrough. Perfect. But then input current limit setting greys out and I cannot adjust it again.
Only known resolution: get into VE config, re-enable powerassist. Then input current becomes adjustable again. Then I can disable powerassist and as long as I stay above 0 input current limit, it operates fine.
Seems like a software bug. Am I missing something?
Also. it used to be that setting input current to 0 would ignore AC input. Please bring that back!!!
MultiPlus Quattro Inverter ChargerCCGX Color Controlbug report
Hi @Pganguet
What firmware are you running on the inverter?
pganguet avatar image pganguet commented ·
Old processor, 209 assistant firmware.
CCGX Product Manual
CCGX Product page
