I have lost the MPPT 150/70 on the colour control. I have changed the cable,tried connecting another device through MPPT and the second device shows on CCGX but not the MPPT 150/70
Did you find the cause already?
I have the same issue. It has been working fine for 2 years and now it is not on the ccgx and the device on menu of ccgx shows it as unavailble. When I disconnect the wire at the bluesolar device the float light comes on. Before that there are no lights. Cable or ccgx input?
Its not the VRM but the CCGX that no longer shows my solar box on the screen.
Is anything else connected ot the GX? Are they misbehaving?
I have power cycled. No effect. I have bmv700 as well as 2 multiplus inverters
The picture attached is when it was working. Now the bottom PV section is missing. It still shows up in settings but shows as not available.
14 People are following this question.
