Bernhard Boser avatar image
Bernhard Boser asked
Multiplus Configuration
I'm planning on getting a Multiplus (24/2000). Apparently these devices are configured using a special interface with a software called Victron Connect.
One option appears to be the MK3-USB (assuming I get a password from my vendor).
Can the Multiplus also be configured with the Cerbo GX? That would be very attractive, as it appears to have many additional features and talks to additional devices.
However, from information I found online I am not sure it can be done.
Does anyone have such a system and can confirm it's possible (or not)?
Many thanks!
MultiPlus Quattro Inverter Chargercerbo gxVictronConnect
Yes you can setup the MultiPlus via the cerbo but the system has to be online.
https://www.victronenergy.com/live/vrm_portal:remote-veconfigure
Updating the firmware can only be done with the MK3 Interface.
