jackoneill avatar image
jackoneill asked
Lorawan Portal ID error
the LED of the LoRaWAN module is flashing green, yet I can't add the module in VRM Portal, I always get the error message "The page with the specified VRM Portal ID or IMEI could not be found." I have entered the portal ID correctly. I saw a post here in the forum that the ID that is on the sticker could be wrong, could that be the problem ? If so do I have to send the module back?
VRMLoRaWAN
jackoneill avatar image jackoneill commented ·
Now it works, after 5 days. For whatever reason....
Hi @JackONeill
Support for these kind of questions should be from your dealer / distributor:
https://www.victronenergy.com/support
The company who sells you the equipment should support you with these questions.
And yes: the portal id should be on the sticker indeed.
can you post a picture of the sticker? Please use a hidden message for this so not everyone can see this.
