this usually means the unit has already been registered. and you will need to contact Victron directly for them to reset it for you. Security ID and a good reason why would be needed inc a copy of the purchase invoice with the units serial number would help. and a copy of the VRM port page showing the units ID
For security reasons and unauthorized use etc it cant be done manually, The original installer would have set it up and thus he is probably the main operator, so its best to get back to them and try to get them to authorize you.
if you get stuck, then PM me only with the above details, with as much info as to why and ill forward it on for you. plus your direct email address and phone number and location
todo a PM Personal message its a selection at the bottom when you reply to this message
Hi @Merlin
Please contact a local dealer, or when not available your local sales agent:
36 People are following this question.
