gabo avatar image
gabo asked
Cant sync batteries and soc not accurate pls help
Hi i have a set up that consist of this
quattro 15kva
2x smartsola mppt 150/100
Ccgx
Lynx shunt and lynx distributor
Old 800ah lead acid battery 48v (16pcs 12v 200ah)
Can someone help me? I will be replacing the lead acid batteries with pylontech, but for now i have to use the lead acid batteries while waiting for the pylontech. Cant seem to get accurate soc and sync batteries
running on ESS, battery monitor is lynx shunt
MultiPlus Quattro Inverter ChargerSOClynx shuntlead-acid
hummingbear avatar image hummingbear commented ยท
can you explain in more details what you mean by "Cant seem to get accurate soc and sync batteries"
0 Likes 0 ยท
