Rob avatar image
Rob asked
Blue power control shows "check device" or “switched off” instead of "charger", "inverter” or "switched off"
I am using a Victron Blue Power Control to operate an Easyplus Compact 12/1600/70. On the Blue power control screen the EasyPlus was automatically (years ago) named "PHOENIX MULTI". I could normally toggle between charger, inverter or (when switched off:) switched off. All I see now is CHECK DEVICE or SWITCHED OFF. Fortunately the charger and inverter are still working properly with the check device message shown. What to do to solve this?
Phoenix InverterEasyPlusblue power panel
Paul B avatar image Paul B commented ·
What has Changed, IE have you done any configuration changes or firmware updates,
I think that the Bluepower control will not work after FW version 159, if you have upgraded then downgrade back to FW 159
Phoenix Inverter product page
Phoenix Inverter Smart product page
