ondra avatar image
ondra asked
Fronius PV Inverter is missing in Dashboard after changing connection from LAN to WiFi
Hi, I had to change the Fronius Primo Inverter connection from LAN to WIFI connection ( AC In on Multi). After changing the connection, the inverter disappeared from the Dashboard and from Device List. In Remote console and in Avdvaced is still visibne and functional. I tried to restart everything, change IP addresses, deleted from the device list, but without success. Please advise how to get the inverter back into the DashBoard. Thank You.
Remote console and Advanced- everything is fine:
Dashborad nad Device list – PV Inverter in ACin missing
VRMFronius
Paul B avatar image
Paul B answered ·
Presume you have done all the basics like a full reboot of the venus unit and then reconnecting to the lan and not the wifi, Also a full system re detect. and that you are on the latest firmware etc
Try to get it back to how it was working and then move forward from there, there is NO magic wand here as it will end up being a diagnostic problem until you find the cause and issue so its try this try that untill you can duplicate the issue or resolve it.
so of sounds like a possible IP conflict or different IP ranges.
Maybe others can help more
