PeterM avatar image
PeterM asked
Can one control charge current in Multiplus depending on weather your grid connected inverter is export power to grid
Can one control charging current in a multiplus to maximise self consumption with a Genius device , Grid connected PV inverter and Energy meter? In principle this is possible - monitor power flow with energy meter and adjust the charging current in the Multiplus using Venus. I do not want to implement ESS for several reasons. I have no need to limit grid tie inverter
MultiPlus Quattro Inverter ChargerVenus GX - VGXEnergy Metercharge current limit
jfleissner avatar image
jfleissner answered ·
Hi!
As far as I know you could only do this by "external means". I would use a RaspberryPi running nodeRed and access the necessary modbus registers on the Venus to change the values according to your available excess power.
J.
PeterM avatar image
PeterM answered ·
Hopefully this facility will be soon be part of the Venus OS. Can all be done in Software
