I have a 1520Ah battery bank ( 12 volt ) being charged off grid by solar panels. I have just installed the Victron BMV712 battery monitor and a little confused as to what the settings should be set at. The solar controller charges with absorption volatge of 14.4v and float voltage of 13.8v.
So for my setup, should my charged voltage for the BMV settings be set to 14.1v, tail current at 2% for 3 minutes or is that not correct ? Thanks for any advice.
