Michael Gane avatar image
Michael Gane asked
Epever MPPT on DBUS not displayed on GUI
I Have a Tracer 40A MPPT that uses Modbus protocol and am running Venus on a raspberry pi.
I've managed to run a dbus service as com.victronenergy.solarcharger.epever_ttyUSB2 and then in a separate script can publish values to it by writing on the system bus.
I can set the /State and the Pv / battery info fine and it displays in the "Device List" in the Venus remote console panel and the values update just fine.
I never get a solar item in the overview screen and it doesn't display on the VRM portal. Is there some values that I need to publish somewhere else other than the `com.victronenergy.solarcharger.epever_ttyUSB2` dbus item to get the solar input to display?
MPPT ControllersVRMVenus OSCCGX Color Control
Kevin Windrem avatar image
Kevin Windrem answered Ā·
You may need to create and populate additional parameters in order to get the system to recognize your dBus service as a valid solar controller. If you have other solar charge controllers, you can look at it in dbus-spy to see what else you might need to create.
For starters, the /Mgmt/... parameters and /Connected and possibly /DeviceInstance.
There is some information about dBus services here:
https://github.com/victronenergy/venus/wiki/dbus-api
and more here:
note the section on generic paths which may be required to make a dBus service recognizable.
also some specifics for solar charge controllers here:
https://github.com/victronenergy/venus/wiki/dbus#solar-chargers
Hope that helps
I have most of the information now showing in the venus remote console.
One thing I can't seem to figure out, is what I should be setting for the following values?
/ProductId
/DeviceInstance
I assume the productId will affect if the overview screen displays the data as solar input?
I can't seem to find any examples anywhere of productIds and the various GitHub dbus pages only let me know it should probably be a hex value?
0 Likes 0 Ā·
/ProductId can be any number you'd like. I just used 0
/DeviceInstance can be any number as long as it is unique across all services with the same service name. There's a brief discussion here:
https://github.com/victronenergy/venus/wiki/dbus-api.
Thanks!
Turns out I wasn't passing some of the values correctly to dbus which was causing the system to crash or not register correctly.
dbus --system com.victronenergy.solarcharger.sample /State SetValue %3
// Note the % after SetValue, /State wasn't working without this
0 Likes 0 Ā·
Nikolay Nedeltchev avatar image
Nikolay Nedeltchev answered Ā·
Hello, @michael-gane.
What you did sounds great! Can you please share? I use the same MPPT controller. Thank you in advance.
Hey, the scripts I use to publish on DBUS are here: https://github.com/ganey/victron-json-mppt
After many weeks of trying, I couldn't poll the Epever for readings frequently enough to keep it stable in Venus, it kept dropping out from the GUI and then the epever would freeze for a few minutes and not provide any readings.
I currently have a raspberry pi reading once a minute from the Epever and writing the values to a json file.
The github scripts read the json file over my local network and publish the values on DBUS.
You could probably read the values once a minute from a raspberry pi running Venus and just publish them frequently on dbus. I tried this but my epever still wasn't happy doing the readings, it might be because it uses the +ve as the common rather than the -ve, newer models (with blue buttons?) use -ve as common instead.
0 Likes 0 Ā·
Thank you for your reply.
I red someware info that this MPPT controller is very sensitive on 'grounding' and this can cause the problems of interupting the data.
0 Likes 0 Ā·
