Is it possible to connect two 24VDC chargers in series to charge a battery bank at 48VDC?
There are apparently no 48VDC chargers with Universal input of 90-265V, 50/60Hz.
I thank you in advance for your assistance.
Regards,
Regards,
I would not try it, as modern chargers use algorithms, which will not suit your battery's
Harold
Hi Harold,
Thanks.
Would you know of an alternative way to charge a 48-volt battery bank with a universal AC voltage input?
Victron has them:
Hi Harold,
Thank you.
Just until a few days ago, I thought this was not an option; however, I recently learned that Victronโs isolation transformerโs online description is incomplete, and I had, therefore, a wrong concept of its full potential.
It seems that the self switching isolation transformer will allow for the following:
I got originally the impression that only the following modes were possible based on the information available online:
What does this have to do with my original question?
The charger was meant to take AC power and convert this to 48VDC for battery storage. Both devices are meant to be used on a boat.
Using both together permits cancelling different voltages and frequencies from shore power. Now it appears that the isolation transformer will feed a Skylla charger at 230VAC, and the Skylla charger will in turn feed a battery bank at 48VDC.
House loads using 12VDC will use a DC to DC converter, and house loads at 230VAC & 50Hz will use a Phoenix inverter to convert from 48VDC.
This allows using motors and compressors which are normally affected by changes in frequency.
Kind regards,
12 People are following this question.
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
Charge rate limited by Victron charge algorithm on flow / high impedance batteries?
Why is my Quattro sending 30.07 volts to my 24 v batteries???
Has anyone connected a solar panel with an optimizer to VE.CAN charge controller?
