I only use my solar system during summer and I'd like to top my batteries off-season with a cheap method. I do not want to invest into another battery charger, so I figured maybe I could simply use the MPPT for this purpose.
@peterpan1, it's worth noting that since the MPPT needs battery voltage +5v to initialize, you'll probably want to run your power supply at a minimum of 18v to make sure the MPPT turns on... 17v will only turn it on if your batteries are at <12v, which obviously is well below where they'll likely be sitting.
Otherwise, yes, this definitely works... I use a variable power supply on my test bench to test MPPTs, though I'm usually running at around 22-24v just for the sake of ease. For a 75/15, your only critical consideration is making sure you don't exceed 75vDC in, which shouldn't be a problem.
Yes you can do this,
make sure that the charger can supply a continuous rated 15 amps or you may damage the charger if the batteries are flat etc.
13 People are following this question.
Large difference between solar blanket voltage output and Victron dashboard
Are 50vdc solar panels wasted on a 12vdc system?
Japanese RV Build— Stuck on Bulk / Configuration Review
Erratic Output from SmartSolar MPPT 100/50
Peak Power Pack 40Ah and SmartSolar charge controller - how to connect & setup
