ceriw avatar image
ceriw asked
Grid tied Combined Heat and Power unit - measure output and report as generator on VRM
Hi, I have built a grid tied combined heat and power unit connected to the output of a Quatro.
The output of the CHP goes through a ET112 so i can monitor its output power.
The system works well if I set the ET112 up as a PV inverter and set to Quatro Output, however I then can not tell what has come from my CHP and what has come from my solar panels within the overview on the VRM portal. If i set the ET112 up as a generator, it will not then let me set its location to the Quatro output.
What I would like to do is be able to set the ET112 up as a generator connected to the Quatro output.
At this point, I would like to say that writing software is not my strong point - i'm a power electronics and mixed signal hardware engineer, so would be grateful of any support.
I've read through the github wiki and as much info as I could find on the Venus OS and adding drivers, how the Dbus hangs together etc.
Digging a bit further, in the dbus-cgwacs/ac_sensor_settings I found this bit of code:
QString AcSensorSettings::getProductName(const QString &serviceType, Position position)
  if (serviceType == "grid")
    return "Grid meter";
  if (serviceType == "genset")
    return "Generator";
  if (serviceType == "pvinverter") {
    QString productName = "PV inverter";
    QString p;
    switch (position) {
    case Input1:
      p = "input 1";
      break;
    case Input2:
      p = "input 2";
      break;
    case Output:
      p = "output";
      break;
    default:
      break;
    if (!p.isEmpty())
      productName.append(" on ").append(p);
    return productName;
  return "AC sensor";
Would it be as simple as doing something like this or am I missing a big part of something?
  if (serviceType == "genset"){
    QString productName = "Generator";
    QString p;
    switch (position) {
    case Input1:
      p = "input 1";
      break;
    case Input2:
      p = "input 2";
      break;
    case Output:
      p = "output";
      break;
    default:
      break;
    QString p;
    switch (position) {
    case Input1:
      p = "input 1";
      break;
    case Input2:
      p = "input 2";
      break;
    case Output:
      p = "output";
      break;
    default:
      break;
    if (!p.isEmpty())
    return productName;
  return "AC sensor";
Many thanks in advance for your help and input.
VRMGeneratorgridchp
