Is there a maximum number of ve can tank sender adapters I can display on the ccgx ?
Maybe my question wasn't very clear. I was asking how many ve can tank sender adaptors I can connect and display on a ccgx
This is not a very difficult or technical question, Maybe someone from victron can answer it for me ?
I can't seem to find the answer in any documentation.
I apologize, I got sidetracked with holiday time etc.
I discovered that you can have 16 of each type of tank (fuel, fresh water, black water, wastewater, oil, live well). There are 10 VE.Can device ID's in Venus.
I'm not sure if the CCGX can read more than those 10 device ID's on the list.
Ah, that's great news, I have 7 tanks to monitor, I wanted to check before I bought the tank adaptors.
Where are you buying the adapters? Everywhere I've looked they are close to $400 USD each or more... I can't imagine buying 7 at that price!
Yes they are expensive, and I can't imagen why. But that is the way it is.
6 People are following this question.
I have a CCGX running 2.31 that no longer sees my tank sensors.
Quattro based SOC % counts down too slowly but CCGX displays correct AC load wattage
Oceanic System - 3271 Volumetric Tank Sender NMEA not recgonised on the Colour GX
Can Color GX use Wifi for remote VRM comms and wired LAN for direct comms to SolarEdge HD Wave
