pegi avatar image
pegi asked
Can CCGX disable Smartsolar charging via VE.direct?
I intend to use a third party LiFeYPO4 battery and use the Aux/Temp-Sensing mechanism like it is described here: https://www.victronenergy.de/upload/documents/Manual-Connecting-other-lithium-battery-systems-to-Multis-and-Quattros-EN.pdf
I will also use a CCGX for monitoring.
My question is: If there is a overvoltage condition
Are the ports monitored all the time even if the charger of a MulitPlus is not running?
And is the current status sent to CCGX and then forwarded to Smartsolar via VE.direct so that Smartsolar stops charging?
If not, is this possible with a different monitoring device?
Kind regards
Peter
MultiPlus Quattro Inverter Chargerbattery chargingLithium BatteryCCGX Color Control
