Enrico Zanolin avatar image
Enrico Zanolin asked
Power consumption of battery maintenance.
I have a MuliPlus II 5kVA 48V running as a UPS, ie grid only input plus batteries. I have 4 x 180AH AGM batteries and I use the following settings
  • Charge curve : Adaptive + BatterySafe
  • Storage mode : checked
  • Absorption voltage : 57.60V
  • Float voltage : 55.20V
  • Charge current : 52A
  • Repeated absorption time : 1 Hr
  • Repeated absorption interval : 7 Days
  • Maximum absorption time : 8 Hr
My question is as follows.
When the system is charged and idle my Venus GX reports the following battery statistics
  • Mode : Storage
  • Charge state : 100%
  • Consumption : 16W
  • Voltage : 52.8V
  • Current : 0.3A
I suspect that this is normal but I just want to double check to ensure I am not damaging the batteries.
Thank you.
Multiplus-IIbattery charging
JohnC avatar image
JohnC answered ·
Hi Enrico.
16W is tiny, perhaps just covering the natural self-discharge of the batteries. I'd consider it normal.
Your 52.8V indicates a 'storage' mode in place, and for a ups setup, the place to be.
