Bill avatar image
Bill asked
Getting all the victron devices to talk together.
I am hooking up 2 Smartsolar 100/50's, BMV712, SBS & RPI-Venus GX to update VRM. My BMV712 will be mounted forward in the RV, far away from the controllers and I am positive the BlueTooth will not be able to connect to the VE.smart-network via the BT. I was hoping there was a diagram the showed how to hook these up so they all communicate but so far, my search has not found anything.
Currently the RPI-GX connect's via VE.Direct to USB interface cables to the SS CC's. And my guess is the BMV will need to be connected the same way?
BMV Battery MonitorVenus OSVenus GX - VGXSmart Battery Sense
Yes, you have to connect the BMV via VE.direct to USB to the Venus device.
The smart network is only to transmit voltage/temperature between BMV, MPPT and SBS, not to a Venus device.
spirou avatar image
spirou answered ·
The BT connection will easily go over 10, maybe 15m. Although that doesn't solve your problem of connecting to RPi, it still means you can probably have a smart network between mppt and bmv.
nebulight avatar image
nebulight answered ·
I'll also add you can't have a VE.Smart network with a GX device with DVCC turned on (conficting data). You can buy a USB Extender kit that can have very far runs. Make sure it's not a normal extension cable, but an extender as it will amplify the signal. I have one in my camper van and it works well. Total length I think is 35ft but I know you can go further.
Venus GX manual
Venus GX product page
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Victron BMV battery monitors product page
