Boekel avatar image
Feature request: Multi on/off through external switch while connected to Venus
It would be a very helpful function if multi's / inverters can be switched on / off more easy.
If one of the digital inputs on the Venus - and / or a more user friendly software switch can be used to turn on / off VE.bus products, this would be very helpfull.
For example:
-electric boat propulsion, 1 small Multi (always on, not connected to Venus through VE.bus), plus bigger 3 phase setup, needed when sailing - or using big loads (electric cooking) the customer now has to go through menu's to turn 3 phase system on.
(though when I think of it, remote control panel overrides Venus AFAIK)
-as another user asked to be able to use a timer to switch on / off the inverter, for this the generator start / stop function can be wired to a digital input - or more gracious a choice in the generator start / stop function to switch inverter instead of relay.
Venus GX - VGXVenus OS
Mark avatar image
Mark answered ·
Yeah.....
When I operate my emergency stop button,the inverter shuts down apart from the leds flashing in an alternating pattern to indicate saftey switch operation,just checked it pulls 2w from the battery when operated!
1 comment Share
Thanks!!
I'll use this than for now, with the added bonus of a Disco-show in the engine room :)
Mark avatar image
Mark answered ·
You could use the emergency shut off assistant for this!
1 comment Share
Unfortunately that doesn't stop the inverters from drawing power.
(at least that's what it says, I didn't measure power consumption myself yet)
