matejs avatar image
matejs asked
VE.Bus Smart Dongle temperature sense
VE.Bus Smart Dongle produce page states:
Secondly it can work as a Voltage- and Temperature-sense device for the inverter/charger. This works with all models, and is especially useful in combination with the MultiPlus-II, as it does not have on-board terminals for Voltage- and Temperature sense wiring
... on-line manual:
On MultiPlus-II models the dongle is, at present, the only way to add an “on-battery” sensing capability.
and:
Likewise, the dongle also monitors VE.Bus communication in order to discover if a Venus-device is supplying the Multi with battery voltage and temperature data. It takes around 4 minutes after power on, or reset, before the dongle decides whether or not to transmit the battery voltage and temperature.
Now, I have MultiPlus II (that is without battery temperature sense capability) and GCCX Venus device. From what I read, I expect that dongle would provide battery temperature data (since there is none present on the bus), but it seems that it does not! When I do dbus-spy there is no signs of battery temperature at all.
I am confused. It seems that VE.Bus Smart Dongle is practically useless (it just provides battery voltage and temperature over bluetooth) when there is GCCX Venus device is present on the bus... or am I wrong. My plan was that VE.Bus Smart Dongle would provide battery temperature to the system.
Thanks,
Matej
temperatureVE.Bus Smart Dongle
jpasop (Victron Energy Staff) avatar image
jpasop (Victron Energy Staff) answered ·
Hi Matej,
The VE.Bus Smart Dongle does send the battery temperature and voltage directly to the MultiPlus-II. The reason why you do not see the temperature on the CCGX using dbus-spy is that the Venus versions up to and including V2.22 do not read the temperature back from the Multi.
Kind regards,
Jos
matejs avatar image matejs commented ·
I have updated CCGX firmware to 2.23 and now I see the temperature in dbus-spy. Thanks!
jpasop (Victron Energy Staff) answered that updating CCGX firmware 2.23 reports battery temperature in dbus-spy. See above for the answer. Accept.
I have updated the manual for this accessory. It now accurately describes the behaviour in various scenarios.
Thanks for asking this question MatejS and leading us to improve the documentation.
https://www.victronenergy.com/live/vebus_smart_dongle_manual
wkirby avatar image
wkirby answered ·
What state are the ports in. It's just an idea.
Despite the lack of sensors, the actual inputs might need to be disabled on the CCGX.
Nothing here.
wkirby avatar image wkirby ♦♦ matejs commented ·
Of course, it's a CCGX. My mistake, sorry I'm out of ideas.
Mark avatar image
Mark answered ·
Found a use for my VE bus smart dongle!
matejs avatar image
matejs answered ·
So, the dongle has is useless if there is Venus device in the system?
