Can I plug the smart dongle into the BMS (remote rj45 socket) to get functionality when using the App on my phone, switch on/off etc.
Which part exactly are you trying to connect it too?
I have a multiplus C12/1600 and wanted to use the smart dongle so I can switch it on/off/inverter only. The dongle worked plugged into the multiplus when I had lead acid batteries, however now I can see what the multiplus is doing but nothing happens when I try to switch off/on etc. The other thing is I’m not getting any error messages.
I was hopping that by plugging the dongle into the remote socket of the ve bus for the Victron lipo battery I would get the functionality back for the multiplus.
6 People are following this question.
Can "VE.BUS-SMART-DONGLE" be used only on devices - that have a "VE.BUS connection" ?
VE BUS SMART DONGLE voltage connected to MULTIPLUS does not match VE BUS input voltage
Multi Control Panel (VE..BUS) - glitch/loosing contact with MultiPlus Compact
VE.Bus Smart Dongle and GX Device Connection
What does the CerboGX add if I have Smart Dongle, Smart Shunt, Smart Solar MPPT and Multiplus?
