martink avatar image
martink asked
Low temperature cut off with Venus temperature sensor
Dear all,
I have a LiFePo Battery which is connected to a MPPT 150/35.
The MPPT is connected to a Venus GX via VE.Direct.
The Venus GX has a temperature sensor connected.
I need to disable the charge of the battery below 5°C.
My first idea was to setup a VE.Smart Network with a Smart Battery Sense, but in the FAQs there is information not to use this if a Venus GX is connected.
The next idea was to use the Venus temperature sensor with the "Shared Temperature"-Feature, but I found out, that this was planned for Venus OS v2.20, but then not released.
I have read that "Shared Temperature" is only available in connection with a BMV-702.
So the only solution is to use a BMV-702 with a temperature sensor and the "Shared Temperature"-Feature enabled in the Venus GX or is there any plan to include the Venus Temperature Sensor in the near future?
What is the best solution for a temperature cut-off in combination with a Venus GX?
Thank you
Martin
MPPT ControllersVenus GX - VGXTemperature SensorCyrix Battery Combiner
Hi @MartinK, most likely that is to wait for Venus OS v2.40; due for release any day now.
I’m 99% sure that it will be able to do what you’re looking for, but now have no time to go through my notes; sorry.
martink avatar image martink commented ·
I have updated to v2.40 and it is working as expected. Thank you.
Elimac avatar image
Elimac answered ·
I found this thread and would like to confirm how to set this up... I too have a temperature sensor connected to Venus GX, but I can't find it in the the DVCC.
How to make the GX-connected sensor appear on the DVCC list of temperature sensors?
Elimac avatar image
Elimac answered ·
Ok, my bad. I found out the issue!
One must select the right type on the Sensor setup page:
1646830637621.pngIf use Generic, it won't show in DVCC. Switched to Battery and now is ok!
