Stevo07 avatar image
Battery temperature for multiple banks
The system will consist of 3 separate battery banks, each with a solar MPPT connected and all wired to a Venus GX for monitoring.
Is it possible to monitor the temperature for each battery bank, the Venus only has 2 temp inputs so I was thinking of using a Smart Battery Sense on each battery. The end user will then pull this data from the Venus using Modbus using their own telemetry.
Is this possible?
MPPT - Solar Charge ControllerVenus GX - VGXTemperature SensorSmart Battery Sense
Jaco Reinecke avatar image
Check if the inverters have a temp sense too, and use that as the 3rd temp sensor?
Share
