while updating my quattro i activated the grid code function. now i wonder if this will be a problem as the quattro is not connected to the grid but charges the battery with a generator.
If you’re not running ESS, and not connected to the grid ever then rather choose the option “none” for using a generator. If you’re using both grid and generator, you could choose different LOM (loss of mains) detection for grid, and disable it for the generator if needed. Let us know what setup you have
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
GX - Generator auto start/stop
13 People are following this question.
victron quattro 24/8000 Relay program
Supplementing grid power with a generator
Quattro and multiplus in offgrid making a loud buzzing noise and generator roughing
Victron Quattro-II 48/5000/70-50-50 QUA482504010 certifications for german grid?
Generation of surplus with the grid, Anti-island protection Quattro.
