merlepeter avatar image
VE Bus SOC not available on VRM
Why is it that I don't get VE Bus SOC [261]on the VRM ? I do get BAttery SOC {258}. Multiplus 5000/48V V4.33 , BMV 702 , Venus GX v2.33.
MultiPlus Quattro Inverter ChargerBMV Battery MonitorSOCvrm remote console
JohnC avatar image
JohnC answered ·
Hi Peter. You can, but you have to select it. A one-or-the-other thing. Select VEBus SOC and you'll lose 258 (the BMV).
Do you really need 2x SOC's? Methinks Victron are sure you don't, so your choice.. :)
merlepeter answered ·
How do I know if MP is using the BMV SOC or its own calculated one. If you disable the BMV will you see the MP one in this field?
Removing one won't default to the other. Needs selecting. Which it's using should be clearly stated, either VEBus SOC or Battery SOC.
