oldcrow avatar image
oldcrow asked
multiplus 12/3000/120 battery charger on but battery isolated. Any issue?
Hi Victron gurus
I have multiplus 12/3000/120 attached to a battery bank (12V SLA 550 Ah total new, at least 4 years old) and my Venus is dropping off the portal. The Venus is powered via the second 12V input/ouput which does not have a battery bank attached but is conveniently located to the Venus.
I suspect the battery isolator has been turned off while some work was done by an engineer and forgotten again. Last time this happened I was on the boat and recurring voltage alarms were what alerted me.
Does having the Multiplus (charger) on but the battery isolated do any harm? (If not then I will wait until I get back to the boat to check my suspicions rather than recalling the engineer).
Regards
Chris
MultiPlus Quattro Inverter ChargerVRMVenus GX - VGX
oldcrow answered ·
Hi all
Looks like failure to upload is an internet access issue as mains powered router is going offline frequently according to my VPN log (independent of VRM).
Sorry
Chris
