dewitpj avatar image
dewitpj asked
K1/K2 relay NC/NO not "normal" ?
Hi Everyone,
We are using the K1 relay to start our generators. The generators require a "closed" connection to start. We connected to the NC and COM points of the relay, programmed the Quattro to close the relay for generator start on <10% SoC and stop at >80% SoC.
This how ever seems to be the other way around. Even a "dead" victron (no AC/DC power) has NO "closed"
I have checked and there is no easy way of monitoring the relay's in the Venus, what am I missing here ?
Thanks
SOCRelay
If your generator need a closed contact to start you have to use COM and NO (normaly open) not NC (normaly closed). T
dewitpj avatar image dewitpj commented ·
In my mind it should be NC (normally closed) so that the Victron has to put effort into keeping it "open" - no ?
(It guards against something going wrong inside the Victron and it's logic failing, causing the relay to go to it's powered off state of NC?)
Matthias Lange - DE avatar image Matthias Lange - DE ♦ dewitpj commented ·
If you set the relay to close to start the generator the relay will switch from COM-NC to COM-NO.
If the Quattro itself is switched off the relay will stay at COM-NC.
dewitpj avatar image dewitpj Matthias Lange - DE ♦ commented ·
Right - this is what I thought too, but the relay on 3 of our Quattro's are COM-NO when powered off...I will triple check this again and advise
