marc-fritschi avatar image
marc-fritschi asked
Cerbo GX SOC to switch generator (relay 1) and to switch water heater (relay 2)
After my batteries are fully charged (SOC >95%), I like to switch on the water heater on (instead of just switching on, I like to control the power of the heater); if the SOC is bellow 90%, I like to switch the water heater off. If the SOC is <20%, I like to start the generator to charge the batteries again up to 50% SOC. Anybody any suggestion how to implement this?
cerbo gxSOCRelay
derrick thomas avatar image
derrick thomas answered ·
Enable generator start/stop function for relay one and use the gx generator control. Use node red to control relay 2 for the heater control. Use relay 2 to drive a high voltage relay for the heater.
chrichri avatar image
chrichri answered ·
Hi, do you have a Multiplus? In this case use the relais 1 from Cerbo to run the genearator and use a relais of the Multiplus via the assistants to control your heater.
