Hi Jaques - the only way I know of (for now) is to use the dashboard, select consumption and then select a useful range (past 2 days or past 7 days both give useful info, the 7 day one counts from 00:00 to 23:59 so it might show usage split over two discharge periods)
See MurrayNated’s answer for the best way, but for completeness there is another way with slightly different features as well, in the advanced tab, click the export button up the top right, and select kWh.
11 People are following this question.
