luis avatar image
luis asked
Unexpected change in battery charging strategy
I have an ESS system with 3 BYD 10 kWh and PV Inverter in AC out. I have set the ESS mode "Optimized (With BatteryLife)". The system has been working properly for months, with the strategy to take as less energy as possible from the Grid.
For a couple of days, the system has changed its behaviour (without changing any parameter). Now the battery has been permanently charged for the last two days.
I wonder if this is a battery maintenance strategy, in order to keep its SOH as higher as possible. Otherwise, I see no reason for this behaviour.
battery chargingBYD
luis avatar image
luis answered ·
It seems that the Multis were set to Charger Only, not physically, but in the CCGX configuration (Multi --> Switch --> Charger Only). Just changed it to ON an everything is working fine again
Hi @Luis
Using 'battery life' is very unusual for lithium batteries, this is a function meant for lead-acid batteries.
Please try restarting the multi's.
luis avatar image luis commented ·
I think the CCGX or the Multis lost configuration. I have:
When I should have:
I assume I have to reboot ESS via the MK2 cable to the Multis?
@Luis
That's strange... Just set it back to 'Optimized without battery life' and it should be good I think. If it happens again please come back.
