tunde olaoye avatar image
Can the CCGX turn on PV Inverter support
After reding guidance here https://www.victronenergy.com/live/ac_coupling:fronius it was not clear that the CCGX can turn on the PV Inverter support. It can turn on ESS but i have an off grid installation and ESS assistant is not suitable for off grid application. I am using Fronius inverter which will be connected to the CCGX
I have not order the USB interface for my installation so wanted to make sure i can still activate the PV inverter support and select the correct settings.
CCGX Color ControlFroniusAssistants
Rob Duthie avatar image
Rob Duthie answered ·
Hi
Yes it supports the Fronius PV inverter as i have system running with one OK.
So you need the MK3 USB to configure the Inverter so the CCGX can run with it if not it won't work.
Regards
Rob D
NZ
OK did you every try to activate the PV inverter assistant with just the CCGX?
ok yeah the only way to do it without the Mk3 Usb device is by using VRM portal remote config! but my internet connection may be super weak so ill get the MK3.
Thanks
