carlrx7 avatar image
carlrx7 asked
Multiplus reporting amps higher than actual
Multiplus is reporting higher than actual current consumption.
The total watts being used are correct on both L1 & L2. However, the calculation of watts / volts does not equal the correct amperage. Attached screenshots below.
Fw 5.10
Venus 3.32
L1
119V * 26.26A = 3,125
309 watt discrepancy
L2, perfect
Please advise
Multiplus-IImultiplus in parallelbug reportcurrent limitamps
Hi @carlrx7,
Please have a read of our book Wiring Unlimited chapter "6.3. System current, VA and Watts" that explains about Power Factor and why Watts doesn't always equal Volts X Amps in an AC circuit.
https://www.victronenergy.com/upload/documents/The_Wiring_Unlimited_book/43562-Wiring_Unlimited-pdf-en.pdf
