hour avatar image
hour asked
BMV & SmartSolar Streetlight to warm battery box
Hi, I have a 190ah LFP battery going in to an ammo can which will be in my truck bed. I'd like to heat the box using small ~25w heat strip(s) when the battery is too cold to charge, but only if it was going to charge in the first place.
What I mean by that, is that if it's the middle of the night and below freezing, don't bother because there's no sun to charge with anyway. Similarly, if I have a foot of snow on the panels and it's freezing outside, don't bother because the panels might not even produce enough voltage to initiate a charge cycle.
I was thinking some combination of the street light function, load ouput, and BMV low temperature relay setting could accomplish this. Likely easily with the ability to invert the streetlight functionality but I do not think that's possible from my research. Maybe some NC relay that the streetlight triggers when it'd normally be operating an actual streetlight (night?)
Any ideas appreciated!
BMV Battery Monitorsmart solar set-up helpTemperature Sensorlynx shunt
Paul B avatar image
Paul B answered ·
whats charging the batteries only the solar or have you got other charging are you using victron MPPTs and or a Multiplus
Victron BMV battery monitors product page
Victron temperature sensor disambiguation table - which product supports which sensor
