James avatar image
James asked
VRM won't give access to my Installation
Hello, I'm hoping someone can help me. I've just finished installing my ESS which includes a Multiplus 2 GX. 2 days ago I was able to see my ESS in the VRM (connected via Ethernet cable via my router to my laptop). Today I logged into the VRM in order carry on setting up things, but although I could see my installation, it would not update (last updated said 2 days ago). I could not figure out how to sort this so thought I would try deleting my installation and then adding it again. However I can't get the VRM to let me add the installation. My PC can see the multiplus on the network, I put in the correct VRN ID code, but access is denied. In hindsight when I was trying to get the VRM to update data for my installation I noticed that 2-way communication was disabled (this wasn't the case 2 days ago though), so I wonder if its because of this, and I wish I had tried to go to venus.local before I deleted my instillation from my VRM. Do I need to ask Victron to unlock something? Hoping one of you has overcome the same issue, and know how I can sort this.
Multiplus-IIVRM
Duivert NL avatar image
Duivert NL answered ·
If you can connect to your multiplus by local network, (wired or directly to multiplus wifi if thats still on) you can turn on 2 ways comms in remote console
Then you should be able to see it in vrm again
VRM is only via internet (browser) or app not a local direct connection
James avatar image James commented ·
just a follow up please. If I can connect with multiplus wifi or bluetooth, then I can make changes via venus.local, is this correct?
Duivert NL avatar image Duivert NL James commented ·
yes
James avatar image James Duivert NL commented ·
Thank you.
James avatar image
James answered ·
Thank you I will try that. I have not been able to connect to the multiplus wifi so far though as windows is not happy with the security, (this is the same when I tried with my iphone), So somehow I need to get round that issue too.
What you also need to do when you get back to base is set up reboot on no contact in the vrm portal submenu.
James avatar image James Alexandra ♦ commented ·
Thank you for that - I will do.
