os-stagair avatar image
os-stagair asked
Black-out system with 80 V battery, Phoenix, and orion
Hello everyone,
I have a 80 V battery with a output current of 200 A.
I want to convert this to 230 V, but therefore I will first decrease the voltage to 24 V.
For that I want to use Orion 110/24-360W ( I wish I could Orion 110/48-360W but I can`t find it so probably it don`t exist).
Then I want to use the Phoenix 24/5000 to make 230Vac.
The problem is the current, because I don`t know if the orion can handle such high current.
I also don`t know what the output current of the orion is. And at least I also don`t know what the needed inputcurrent must be for the phoenix.
The idea of this is that with a 80V battery I can provide elektricity to a building in case of a black out. And for that I need a converting systeem from 80 Vdc to 230 Vac with high power. This systeem described above is the only way I could figure out so if anyone have a better idea pleas let me know.
Phoenix InverterbatterygridOrion DC-DC Converters not smartbattery system voltage
What battery do you have?
Can you cut it in half?
Meine_Energiewende avatar image
Meine_Energiewende answered ·
That will not work.
360W at 24 Volts are 15 Amps.
You can not feed a 5000 Watts System with a 360 Watts System .... or lets say: you may do that but you can not expect more power than the weakest System has (in this case the orion).
And: the orion is able to produce 110/230 Volts out of 12/24 volts ..... not vice versa.
80 Volts is way to high for every kind of victron equipment.
Jens
Phoenix Inverter product page
Phoenix Inverter Smart product page
