davidchurch avatar image
davidchurch asked
Victron Quattro and Multi RS
Hi, I currently have a Multi RS working with a cerbo gx. Standard setup and all working well.
I'm looking to buy a 15kva quattro soon.
My question is can they both run alongside each other on the same cerbo gx? I'm not looking to parrallell the ac out but they will share the DC and cerbo.
I would just like to keep the Multi rs to do other bits like the water heater. The quattro will run the rest of the house.
Many thanks!
Dave
cerbo gxquattro 10kvaMulti RSQuattro-II
snoobler avatar image
snoobler answered ·
No. Only one inverter or parallel group of identical inverters per GX device.
andrii-podanenko avatar image
andrii-podanenko answered ·
I have 2 inverters in series, first - non Victron, second - MultiRS
I put em24 meter and system works good
I have no monitoring for non Victron one, but I don't need it.
For the second Victron MultiPlus-II - I have another Cerbo
Depends on what you need from monitoring in your setup.
Alex Pescaru avatar image
Alex Pescaru answered ·
Frankly, I don't see why not if they were assigned different NADs or are on different interfaces...
If that is possible or not... Remains to be seen.
Alexandra avatar image
Alexandra answered ·
@David.church
One would be controlled by the GX and the other could have monitoring only.
So yes both can be connected.
Fideri avatar image Fideri commented ·
I read somewhere that the additional one has to be connected via MK3? But only stats of the original one are shown on GX and therefore on VRM?
Alexandra avatar image Alexandra ♦ Fideri commented ·
On the dashboard the main one connected to the ve bus will appear.
In advanced you can create your ow monitoring for the other.
