bolie avatar image
bolie asked
Multi RS Solar, Cerbo A/C current limit and Inverter controls
Hello All,
I have a system with both a Multi RS Solar and a Cerbo. Currently the A/C current limit and Inverter do not operate through the dedicated control on the pages screen. It can be adjusted by going into the device and changing the settings. On a previous system (Multi Plus II) the Cerbo's dedicated control on the pages screen work perfectly. Am I missing something or is this function currently not combatable with the Multi RS Solar? 1685430848232.png
cerbo gxMulti RS
Thanks for reporting, looks like a bug/not yet implemented. I’ll pass it on to the RS team.
Alexandra avatar image
Alexandra answered ·
@Bolie
The Multi RS is not a VE Bus product so just checking how and where you have connected it to the cerbo.
Are you using VE CAN or VE direct?
6 comments
bolie avatar image bolie commented ·
Thanks for the prompt reply. I am using VE CAN.
Alexandra avatar image Alexandra ♦ bolie commented ·
And it is definitely in the can port and terminated?
bolie avatar image bolie Alexandra ♦ commented ·
Yes, it is definitely in the CAN port. I can control it from both the Cerbo and through VRM. Firmware of the Multi RS Solar is 1.11 so I will update it now to 1.12 and see if there is a change after the update.
bolie avatar image bolie bolie commented ·
Controls still not available from this screen after firmware update.
Please note I can control the Inverter and current limit from the Cerbo via entering the device. 1685457126542.png
@Bolie
Confirm you are using a GUI mod firmware on the GX?
There are no GUI Mods. All original and the latest firmware on the RS and Cerbo.
