andrew-leversha avatar image
andrew-leversha asked
Multi RS 48/6000 not reading battery SOC correctly
I've recently installed a Multi RS 6000/48 with a Freedom Won Lite 10/8 48V Lithium Battery
We are having an issue where the Multi RS won’t pick up the SOC from the cerbo/bms.
This means that when I try to program the inverter to shut down at 20% to protect the battery it automatically shuts down because it thinks battery SOC is 0%
It's also causing an issue in that I can't use it as an intentional island being able to set it to call on a generator or the grid when it battery drops to a certain SOC say 25%.
All devices are connected to a cerbo gx with Freedom plugged into battery bms port set at 500kb/s, Multi RS into VE.can port set at 250kb/s.
Everything is reporting as it should to the cerbo gx, I can see battery SOC on the cerbo however the Multi RS is not picking this up
Any advice on this would be greatly appreciated.
Thanks!
cerbo gxMulti RS
snoobler avatar image
snoobler answered ·
in GX:
DVCC enabled?
BMS selected as default battery monitor?
kevgermany avatar image
kevgermany answered ·
