199-big avatar image
199-big asked
buck boost and LiFePO4 - best settings
I would like to know the best settings for my 50A buck boost and LiFePO4 smart battery LFP-Smart 12,8/150.
First things I changed was within TSConfig:
20: Output voltage from 14,4V to 14,2V (recommended for LFP-Smart 12,8/150)
31: Battery voltage charge protection (10.0V (out) and 20A)
The problem is, that the voltage at my battery (connected at AB from BMS12/200) is at first try lower than 10,0V
50: Converter on/off by input voltage
I tried to reduce the Switch off delay from 1 min to zero (no load from starting battery after switch off).
But this is not working – it’s like pumping (on – off – on …).
1 minute of 50A from starting battery will not hurt – hopefully
Are there more important configurations to change in my setting with LFP-Smart and BMS?
THX for any help
Lithium BatteryBMSOrion DC-DC Converters not smart
199-big answered ·
This are my actual settings:
31 is for the output not the input
To prevent discharging the starter battery after the motor stops you should set the 24 higher.
199-big avatar image 199-big commented ·
THX for your feedback :-)
You are right - 31 is regarding the output (monitor 3) but nonetheless I disabled the 31 to always start with maximum output current.
Regarding 24 I will give it a try.
bert65 avatar image
bert65 answered ·
I am using the purple pin to switch the converter on /off. Should I also select 'Powerdown' in that case? And can I use the same settings (other than those 2)
