jaxley avatar image
jaxley asked
Smart BMS 12/200 and Blue Smart IP67 12/25
Smart BMS 12/200 with Victron Lithium Smart 330Ah. There is a SmartShunt connected as well.
I want to integrate a Blue Smart 12/25 into the system.
Two Questions:
1. When I'm bench testing the system in my garage, can I connect the Blue Smart to the Smart BMS Alternator+ in Power Supply mode to simulate a connected alternator? If I set the current to >13V will this simulate charging and so I can test the load/charge disconnect?
2. In normal operation, do I put it on the System+ side in Power Supply at >13V mode as well? My electrical diagram will (eventually) look nearly identical to this one:
https://community.victronenergy.com/questions/204022/smart-bms-12200-to-multiplus-122000-for-camper-sys.html
BMSSmartShunt
jaxley avatar image
jaxley answered ·
For anyone else that wants to bench test a Smart BMS with a Blue Smart, the answers are:
1. yes
2. yes
