noah-guthrie avatar image
noah-guthrie asked
MPPT 100/15
I am looking to wire my 100/15 MPPT controller to my 85w hood mounted solar panel. Is it correct that I need to add a fuse on the positive connections into the controller and output to the battery? How big of a fuse?
Just to share more info on the setup, I am wiring two Dakota lithium 135ah dl+ batteries in parallel directly from the alternator and had to get a different charge controller that supports lithium.
Thanks in advance,
-Noah
MPPT SmartSolarLithium Batteryfuses
klim8skeptic avatar image
klim8skeptic answered ·
@Noah Guthrie The Manual shows the minimum requirements regarding fusing.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
Battery Compatibility
