mark-allen avatar image
mark-allen asked
Do I need a fuse and or circuit breaker?
I’m new to solar and have a question on to fuse or not.
I have a fish pond that I would like to run the equipment on solar.
I purchased a Victron BlueSolar 115W panel, SmartSolar 75/15 controller, and 130Ah LFP.
Please excuse my ignorance, should I be using a fuse or circuit breaker in any part of the installation, also can I store the battery and charge controller in a partially buried (adjacent to small fish pond) watertight container or is ample air circulation required?
Thanks.
MPPT SmartSolarLithium Batteryfuses
Paul B avatar image
Paul B answered ·
air flow cooling is required for the 75/15 or some other form of heat transfer from the sealed box to the outside area
yes a fuse or circuit breaker (not both)should always be used, its your choice as to which one.
there should be a 15amp Breaker or fuse between the MPPT unit and the battery and also one between the battery and the pump.
mark-allen avatar image mark-allen commented ·
Thanks Paul, I appreciate the help.
orangecowboy avatar image orangecowboy commented ·
can u suggest a fuse holder or or a circuit breaker between the battery and charge controller? Looking on amazon I only see higher amp options.
and what size wire is used from the fuse into the charge controller?
thanks
Fuses & fuse holders Product Page.
Battery Compatibility
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
