kevinc avatar image
kevinc asked
Batteries stopped charging/discharging
Hi, my system has been running well for over a year, looking at the VRM app today i see that the batteries have stopped charging and discharging, with the batteries being stuck at 29% since the 4th of April. They should have been chanrginf and discharging daily.
Looking at the remote console notifications there allot of messages saying "Low battery voltage" from the multiplus2.
To try and resolve i swithced the pylontech battereies on and off but now the remote console says batteries anot connected and MPPT says error 67
Will it take a little time for the batteries to auto connect or is there other problems?
Multiplus-IIcerbo gxPylontechmppt rs
@KevinC
If the pylontec is not appearing under the devices list, then battery Comms are the issue. Check the can cable and set up there.
Error 67 means the same thing. The battery is not communicating.
So that is the side to troubleshoot.
kevinc avatar image kevinc Alexandra ♦ commented ·
Thanks Alexandres, i have everything communicating now but there is still no power going into or out of the batteries
Alexandra answered ·
@KevinC
Is the fuse between the battery and the system ok?
duivert avatar image duivert commented ·
good point! @Alexandra
Paul B avatar image
Paul B answered ·
or the pylontecs BMS has turned the battery off, maybe a cell issue, so check your bms readings
kevinc avatar image kevinc commented ·
Thanks Paul, where would i find the bms readings, i only have the VRM app and do not see it on there.
Everything is communicating now but no power goes into or out of the battery (from grid or solar)
The power lights are flashing on the battery so they look switched on, however on the Remote console/ notifications Multi plus -11 is getting a Low battery voltage alarm.
At present, i am getting power from the MPPT but it will only go through to the inverter to get used for AC loads and Grid. If change my Battery SOC setting from 10 to above the current battery level to force a charge, then power from the MPPT goes to zero
duivert answered ·
VRM app > remote console > device list > pylontech battery
there you can see all the available pylontech data
kevinc avatar image
kevinc answered ·
so looking in the battery section i see no problems although i dont really know what i am looking for, there is nothing obvious.
Details, there are 0 modules offline
Nr of modules blocking charge / discharge zero
Alarms, all say ok
Module level alarms is blank
Device, connected is Yes
7 comments
That looks fine indeed, maybe check all your other settings in the gx,
Under settings, dvcc should be forced on by the pylontech bms
kevinc avatar image kevinc duivert commented ·
Here are the dvcc settings, are they ok? screenshot-20240415-183128-vrm.jpgscreenshot-20240415-183150-vrm.jpg
duivert avatar image duivert kevinc commented ·
Yeah looks ok
Fideri avatar image Fideri commented ·
Also, get software from Pylontech to look inside each module.
kevinc avatar image kevinc Fideri commented ·
This sounds like it may be above my pay grade, i am the homeowner with no real experience with this.
Would it be hard to do?
Did you install the system yourself or let a installer do it? In the last case you might want to contact them before chaning settings yourself
Checking the batterys with pylontech software is an option, but without technical understanding its not recommended
I had one of my friends install it, he does install systems but this was his first victron system.
Yes i agree, if this is not an easy fix i will contact him.
kevinc avatar image
kevinc answered ·
This is the only notification that i am getting now, can you confirm i am getting this on the multiplus because there is no power flowing from the pylontech batteries
what is the actual battery voltage?
duivert answered ·
maybe also follow all steps in these manuals with your friend, to see if everything is setup right:
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
and if your system is configured as ESS:
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/index-en.html
there is a chapter in the ESS manual about low battery alarms:
10.5. Q5: How can I suppress low battery warnings?
Thanks.
The system was up and running for over a year so i asume it was set up correctly.
I assume the low battery warning is because there is no power coming from or going to the battery?
kevinc avatar image
kevinc answered ·
Here are some screenshots showing battery info
screenshot-20240416-105433-vrm.jpgscreenshot-20240416-105307-vrm.jpgscreenshot-20240416-105733-vrm.jpg
duivert answered ·
what is in the pylontech parameters in remote console?
VRM app > remote console > device list > pylontech battery > parameters
duivert answered ·
you could also check with the victron connect app (different app then vrm app) what your mppt settings are, should be these values:
MPPT Parameter Setting
Battery voltage. 48V
Absorption voltage 52V
kevinc avatar image
kevinc answered ·
Here is the battery parameters from the remote console
kevinc avatar image
kevinc answered ·
Looking at the Victron connect app, i do not see mppt settings.
What do i want to connect to with the victron connect app, is it the mppt or cerbo?
This is what i see whaen connecting to the mppt, i do notice when looking here that sometimes the battery voltage is over 53.2V, could that be the problem?
mppt, click on the gearwheel for settings
battery readings in your last preview are not the battery it self, its the DC bus voltage
ah, what is the path to the parameters you need, i cant see them.
duivert answered ·
mppt > gearwheel > battery
kevinc avatar image
kevinc answered ·
Sorry, i see it now
Looks like they are correct?
yes looks good... i don't see why its not charging the battery's... it should do that
did you already try to restart the whole system? by turning everything off and restart
(connected equipment on AC out will turn off also!)
Yeh, i had done that and just did it again now to be sure. Still the same problem
kevinc avatar image
kevinc answered ·
The fuses visually look ok but i have not had an electriciaqn check them.
kevinc avatar image
kevinc answered ·
If these fuses blow is there any visual signs or would the victron system pick it up and give a warning?
No power is going into or out of the battery and if you guys dont see any problems with the settings, indeed i guess this might be the problem.
If i switch everything off and remove the fuse might it show visual signs on the hidden side?
Could be visual signs best is to measure it with an ohm or continuity tester
kevinc avatar image
kevinc answered ·
Thanks guys, i have ordered a new fuse and plan to swap it over tomorrow, lets wait and see.
4 comments
did you have an change to measure the fuse or was it visualy broken?
Alexandra avatar image Alexandra ♦ duivert commented ·
The window is on the other side. They would have to be removed to visually check them .
duivert avatar image duivert Alexandra ♦ commented ·
i know, i was just wondering if it really was only broken a fuse :)
i didnt check it or take it out, i will do that tomorrow when the new one arrives and i will just swap it over.
kevinc avatar image
kevinc answered ·
Thanks again guys.
The new Mega fuse arrived this morning so i switched everything off and removed the old fuse, indeed on the hidden side there was a window which did show it had blown, i have no idea why it would not be installed with the window visable!
I replaced it with the new fuse and everything is working now :)
great to hear the problem is solved!
kevinc avatar image
kevinc answered ·
Yes i know, a big thanks to you and Alexandra for getting to the bottom of this
