martin-modr avatar image
martin-modr asked
REMOTE CONSOLE - Failed to connect. How to enable Remote Console without acces to Remote Console?
I updated the FW in Cerbo from 3.10 to 3.30.
During this, my internet connection dropped, but then it finished, it didn't report any errors.
In the list on the Gateway I see:
Firmware version: v3.30
Remote Console on VRM: Enabled and up
Two way communication: Enabled
Remote support: Enabled and online - 84.22..........
I will get to NR, programming and Dashboard.
BUT!
I can't get into the Remote Console!
I try it like this:
1) via VRM - it doesn't work
2) direct login via LAN address 192.168.0.XXX - not possible
3) direct login to WIFI Cerbo GX, that's a different address, but again it doesn't work
4) I also tried the VictronConnect application with wifi, it's the same there
5) if I log in to VictronConnect via Bluetooth, I can change some things in the network settings there, but I can't go to the Remote Console from thereI probably need to get to the Remote Console to allow LAN connections there, but I can't log in there.
I didn't change any settings, just updated the FW.
No idea what to do with it?
I saw this topic here but no solution.
cerbo gxfirmware updateremote console
martin-modr answered ·
SOLVED using HDMI monitor, USB mouse and USB keyboard to Cerbo GX. Then restart from Cerbo GX.
When in doubt, just pull the plug, That's the tried and tested, old-school approach.
