Have the above system fitted to a cerbo gx, having issues with the inverter not showing an ac load in the dashboard.
Have I missed a setting?
How is the Inverter connected to the Cerbo?
But the other numbers indicate no load. So probably will work if you plug in something that draws more watts.
How to change the Owner of a VRM installation
106 People are following this question.
